Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 02-15-2014, 04:55 PM
chipman181 chipman181 is offline
Default Briggs carb problems
My carb seems to be flooding the engine.When the engine is stopped the gas pours out the carb.I've taken the carb apart and cleaned but found that the float has gas in it,could this be the problem?Thanks
Old 02-15-2014, 05:02 PM
Yep that would do it.
Old 02-15-2014, 10:03 PM
That's it. Sometimes the float will develop a pinhole, fills up with fuel, and cannot float.
Seen that a few times, but not really often.
Only thing better than having a Cub Cadet is USING one
Old 02-16-2014, 10:04 AM
Any way for a quick fix on the pin hole or should I look for another float.Thanks
Old 02-16-2014, 10:12 AM
A possible fix
Get a package of that "gas tank repair epoxy" and mix it up, and put the very smallest dab on the pin hole, just enough to seal the leak. If you use too much, the float will be too heavy to work properly.
I told one Guy about this repair a long time back, but he didn't drain the float BEFORE applying the epoxy, then complained I gave him bad advice about carb repair.
Sheeeeeeeesh...some people should not touch engines, except to use them for the intended purpose.
Old 02-16-2014, 10:20 AM
kostendorf's Avatar
I think it should be soldered, but if there is one hole there may be more about to emerge. A float is not that expensive.
Old 02-16-2014, 10:26 AM
Kostendorf has a good suggestion, too. Float could be soldered, depending on what it is made from.
The best fix is to replace the float, but if you can't find a float you have a couple of alternate ways to fix it.
