Cub Cadet 1730
i think my pedal switch is bad what holds it on and how do i get to it remove deck or fuel tank cant see nothing
What do you mean by your pedal switch? The brake safety switch?
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
cub cadet 1730
yes sir sorry for the multiple post
I'm not 100% sure, but you probably have to take off the gas tank. It would probably be easier to get to it. Could you see where the switch is? Are you sure this is your problem?
cub cadet 1730
yes found switch when you try to crank it light on dash says depress peddle switch button goes in but i cant test it without it in my hand thanks
Good luck!
cub cadet 1730
ok checked brake pedal safety when depressed makes one side and breaks other checked seat switch does the same can someone help with this what to check next of course fuse is good thanks all
You did make sure the PTO is not engaged, right? And that the drive lever is in neutral? Is the tractor doing anything at all when you turn the key?
cub cadet 1730
pto in off position and lever in neutral no clicks or nothing light just comes on that says depress peddle
Could you bypass the pedal switch and see if it does anything? Then you will know if it is the switch or something else.
