#31
Just remove the four bolts into the oil pan and move the engine forward. The driveshaft has a 3/8" diameter pin on the flange end that locates in the pump coupler ( rear ) that is about 1/2" long. |
#32
You will have to contact him personally. He makes them himself on a lathe. I think you can click here to contact him. Great guy to deal with!!!
https://www.facebook.com/CubCadetandKohlerparts/ Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
#33
Thanks, We got the engine out now and have the tractor flipped up so I can get to it. I just hit the bottom with degreaser the other day, then I just scrubbed with soap and water today. 35 degrees outside. I just retreated indoors. I think I am going to buy the big Husquavarna garden tractor for this summer and I am going to go through the cub. Many parts like the pulley arms are ovaled out. My father in law has a guy that will weld them and re-drill the holes. I'm not going to do a full restoration, but I'm going to freshen it up. I have already fixed some things, but I want the front end rebuilt with new tie rods and bushings and things like that. My fiance is really supportive and that is great. I want to eventually restore a Cub Original for parades. Thanks for all of the advise and input. Once I get my surgery I'll be able to go at it a bit more.
#34
Sorry, I forgot to ask. The bar across the front that the pulleys are attached to, and is welded to the frame, how do you get a new one? I'm sure I can grind it and the ends and remove, but I would like to replace. Thank you.
#35
If that's what you need, ebay, c-list, or put up a wanted ad in the "Wanted" section on this site. Someone has one to sell. |
#36
Updated photos of work in progress
It's been cold, and now raining, so things are going slow. I got it cleaned up, but my fiance's dad is going to let me use his steam cleaner, which will really help. I used soap and a scrub brush and got it pretty clean. |
#37
OK, the shaft is good, the valves all move on the pump, filter is the correct one, does this now point to a bad pump? If so, I found a Cub salvage yard 20 min from me.
#38
I am still healing from surgery. My two hour surgery turned into 5 hours, and I am now titanium from mid femur to the top of my shin bone. I bought another mower, my sons bought me a welder, so game on. I am doing a rebuild. I am going to start by playing drill and fill with the welder on all of the worn out and elongated holes and slots and get things tightened up.
#39
Is that a Magnum in a 127??? Or is it just a black replacement?
#40
I see a coil so it must be a replacement engine.
