Greg Rozar AKA- CubDieselFan
Old 08-22-2014, 06:32 PM
bocephus1991's Avatar
Default Question on undersized rods
Took. My engine to the machine shop after work told what I wanted done and will have to wait a week till the get back to me with measurements , anyways I was told if it needed a .20 under rod it would need a bearing installed. I thought a .20 under rod didn't have bearing?
Brian
Old 08-22-2014, 06:47 PM
cubs-n-bxrs's Avatar
You can get a .020 under rod through Kustom Lawn and Garden. BTDT Extremely fast shipping. Ordered one day received rod 2 days later.
Old 08-22-2014, 07:07 PM
I'm going to start doing bearing inserts on all my rods. That way, they are re-usable. You can go with a .020" under if you want. My machine shop will machine the rod and install the bearing for the same price or just a little less, than a new rod. Your choice.
Old 08-22-2014, 07:56 PM
I don't know what size I need as of yet. I just thought a .20 under rod was made like a standard size just larger to accommodate the turning of the crank from machining . From way it looked could be within spec, both rod and crank look fine. Oh he also advised against reusing the old rod even if good on specs . He sad he would worry about fatigue of the rod.
Brian
Old 08-22-2014, 07:59 PM
Originally Posted by bocephus1991 View Post
......I just thought a .20 under rod was made like a standard size just larger to accommodate the turning of the crank from machining . ......
That is correct.
I've not seen very many cranks that were "withing spec" enough that they didn't need turned. Expect at least a .010" under.
Old 08-22-2014, 09:05 PM
Please excuse the machinist ( ) as he nitpicks your post.
When the crankshaft rod journal is turned .020 undersized, it will require a connecting rod with a smaller hole size to have the correct clearance.
He is correct on the rod, aluminum fatigues with use and it will fail at some point.
Old 08-22-2014, 09:11 PM
That's what I was thinking too .10" under. The place was busy several 6 cylinder blocks a 3 cylinder jd block , quite a few diesel heads. It is a new building, their old one burned last fall they lost all their machines several engines. Thanks Jonathan for confirming what I thought about the rod . That's ok Jeff no problem with nit pickin !
Brian
Old 08-22-2014, 09:18 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I thought of doing that at one time but I came to the conclusion that just using a new rod was better. I really don't trust boring a used rods unless it the K361 rod
Old 08-22-2014, 10:57 PM
Afraid of rod fatigue? Dean (my machinist) and I discussed rod fatigue. We didn't think it would be an issue, but weren't sure.
Do you run any of your motors with bearing inserts? What about boring a new rod?
I may still try it on some of my own (just because). I've got a few good looking Kohler rods that I wouldn't re-install just because they are used, but they aren't "spun".
Old 08-22-2014, 11:30 PM
dvogtvpe's Avatar
yep, its a bad rod to start with. I wouldn't be afraid to insert a new one. I stopped doing inserts when I could no longer get or find the K361 rod. the last few stocker pullers I did ,I put a stock length aftermarket rod in. you do need to rebalance the rotating assembly
