Greg Rozar AKA- CubDieselFan
Old 02-19-2018, 09:17 AM
Originally Posted by riesedesperado6170 View Post
Kustom Lawn and Garden sells reman long blocks i got one and love it. they were 1400.00, but that was 4 years ago
I've seen their listings on FeeBay, I have rebuilt engines before (just not a Kohler twin, yet) I have 3 here (only the 1 twin, other 2 are a K321 and a K341) to go thru, I'm hoping to *not" have $1400 into the 3 combined if you know what I mean, ha ha... but I know theyre a business that needs to make money too....
Old 02-23-2018, 05:02 PM
nother question.... gonna need this anyways whether it solves the oil consumption issue, or as part of a total overhaul... so I got a new breather element for the engine. but it don't come with what Kohler is calling the Umbrella seal valve" in the breather.... will definitely be as bad or worse on oil consumption without that... shows as discontinued from Kohler. PN 52 462 01. Any idea where I can find this? It reminds me of the check valve behind the accelerator pump on an old Ford 2bbl carb.
in the parts breakdown it is key #8.
Old 02-23-2018, 07:10 PM
IIRR the replacement valve ( new style) is of the reed valve type, not the umbrella type (old style).
Old 02-23-2018, 07:43 PM
yeah it has a reed in it but (ok let me grab it from the counter, hang on)
the reed has 1 hole in it (not counting the rivet that holds it together) and the base has 2.... the one hole (obviously) is to go over the mounting stud, of course....
Bear with me as I have not been inside of as many Kohler twins as I have K series singles, and it has been a while since I did the one on my KT, so I'm having a brain fart....
I remember the original one from the KT being different from the replacement, but didn't remember "how" it was different.... that must have been it. I was thinking for some stupid unknown reason, that it had the reed, and it had that rubber check valve TOO..... not one or the other.
I do remember that the one I used on the KT was the same PN as what they called for on the Magnums and that the original PN for that engine had been superseded....
I haven't taken the original apart yet on this Magnum.... was waiting on the parts to arrive, have too many projects apart all at once besides that one.
Old 02-24-2018, 08:06 AM
Be sure to use the little orange neoprene sleeve on the mounting stud, inside the breather cover, 'cause if you don't, it will burn/slobber oil into the air cleaner.
And if y'all don't believe me, just try it without. BTDT
Old 02-24-2018, 02:37 PM
Yeah I have made that mistake before on another engine many years ago.
Being as how this engine is being fixed up as a backup, I have a couple of other ones that I need to do 1st...so i'll swap out the breather, run it awhile and see what it does, and go from there. In the meantime I have a K321 in pieces that needs to see the machine shop 1st.
