Greg Rozar AKA- CubDieselFan
Old 12-07-2017, 10:02 AM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Default Where are the carburetors?
Where are you getting new carbs? Need one for my 12 hp 1250.(K-301AQS)
Old 12-07-2017, 10:13 AM
Why not just rebuild the one you have?
Old 12-07-2017, 10:39 AM
bllwnkl's Avatar
Well, the throttle shaft is extremely loose, the throttle plate has come loose and the tiny screws stripped so I tried to fix it with Lock-Tite and it doesn't really fit very good anymore, the threads are stripping where the air cleaner housing mounts, and I figured that it might be not worth it given the age of the carb. Can all that be rebuilt?
Old 12-07-2017, 10:42 AM
Terry C's Avatar
Terry C Terry C is offline
Knock offs on ebay seem to work ok. Several have tried them and reports were positive.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-07-2017, 01:34 PM
zcub22 zcub22 is offline
I bought one from Ebay for a K321 and it's working fine. The only problem is the choke bracket didn't fit. I had to change it to the original.
Old 12-07-2017, 02:44 PM
Yes, that can all be rebuilt. I am not 100% sure on where to get all the parts, but I can find out if you want to go that route.
Old 12-07-2017, 03:12 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
I got one for my Gravely (K181) and my 122. My 122 was missing a carb when I got it, so it was the only route. Works well so far. The one on the Gravely worked great out of the box, but after a week or two the float got fuel in it (they're plastic). I just swapped out the brass float from the old Gravely carb and it works great now too. My 149, and 1650 had solid carbs on them, so I just rebuilt those.
For $15, you can't beat them. And if you have a brass float in your current carb, I'd just swap that out before you install.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 12-07-2017, 07:49 PM
bllwnkl's Avatar
Thanks for the replies. I ordered one online. I'm going to research about fixing the old one. If it can be fixed, I'll have it to fall back on if the "cheap" one fails.
Thread Tools
Display Modes
