CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 12-09-2017, 07:24 AM
Dlittle1's Avatar
Dlittle1 Dlittle1 is offline
I already pulled the head and the valves are not stuck.
Old 12-09-2017, 07:29 AM
Dumb question I know but Did you verify that the piston is moving?
Old 12-09-2017, 08:51 AM
ok the valves are not stuck, but are they closing tightly?
Usually a worn engine will have low compression but not complete loss of compression.
in the absence of any compression, either the piston is not moving, or the valves not closing, -------------
-----------or the spark plug is removed, Ha,LOL!
Old 12-09-2017, 09:59 AM
ironman's Avatar
ironman ironman is offline
Originally Posted by sir_lancealot View Post
Doesn't the K series have a compression release? Or is that only on the 10+hp engines?
My K161 (7 hp), which is an early spec number, DOES have ACR.
Old 12-09-2017, 11:42 AM
sir_lancealot sir_lancealot is offline
Thanks for the confirmation, Ironman. So if it has ACR, doesn’t that mean the compression will not check properly?
Old 12-09-2017, 12:56 PM
ironman's Avatar
This is directly from the Kohler K Series Service Manual....
"Compression Test
Because these engines are equipped with an
automatic compression release system (ACR), it is
difficult to obtain an accurate compression reading.
To check the condition of the combustion chamber
and related mechanisms, physical inspection and a
crankcase vacuum test are recommended."
Old 12-09-2017, 04:08 PM
jbrewer's Avatar
jbrewer jbrewer is offline
I'd put it back together and start it. I believe more tractors are scrapped out because of "repairing them" than wearout.
Share some pix, you got a nice tractor it sounds like.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-17-2017, 12:03 PM
Dlittle1's Avatar
Heres what it looked like when I got it
Old 12-17-2017, 12:43 PM
twoton twoton is offline
Attaching pictures;
http://www.onlycubcadets.net/forum/s...=6213#post6213
