Greg Rozar AKA- CubDieselFan
Old 12-10-2017, 04:33 PM
twoton twoton is offline
Good to see your progress there jsoluna.
Old 12-10-2017, 09:43 PM
Bob95065 Bob95065 is offline
Originally Posted by jsoluna View Post
NVH (Noise, Vibration, Harshness) Corrections.
I want to make a meme for the "QuietLine Owner's Starter Pack", and in that pack there will certainly be a couple spools of these two types of trim. They are absolutely invaluable in making these tractors more enjoyable to drive.
In addition to isolation of metal-to-metal contact in these areas, I also found one of the engine tins had broken loose (the one behind the coil). I took it out and welded it back into shape where all the bolt holes and had broken off.
Went through the ISO mounts and snugged them up so that the washers weren't loose, and then backed off a little at a time until the tractor smoothed out again. The previous owner cared enough to pay for the Cub style mounts, which work well, even if they are a little stiffer than the original ones.
What is the part number and source for the trim you used?
Old 12-11-2017, 05:02 AM
jsoluna's Avatar
jsoluna jsoluna is offline
Small Trim:
Brand: 4M / MATCC
Part Number: COMINU020130
Source: eBay
Rubber Edge Trim
Description:
Width: 10mm
Edge Thickness: 2mm
Grip range: 1.0mm to 2.5mm
Large Trim:
Brand: N/A
Part Number: D012-10F
Source: eBay
1/4"
Large Edge Trim
Description:
Edge Trim Black Large
U Height 0.656"
0.039"-0.178" Grip Range
http://www.solunagarage.com
Old 12-17-2017, 06:10 AM
jsoluna's Avatar
Just threw on the front blade real quick to see how it worked out. It's certainly been used and needs some attention in pretty much the same way the tractor itself did, but it's all there.
Old 12-17-2017, 06:12 AM
jsoluna's Avatar
Started fixing the huge cutouts in the fender pan.
Old 12-17-2017, 07:26 AM
john hall's Avatar
What were the cut outs for? My guess is a homemade bagger.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-17-2017, 08:27 AM
jsoluna's Avatar
There was a strange hitch plate on the back, I'll take a pic and show ya. Not sure what the cutouts were for but it ended up causing the fender pan to get bent in at the ends and sides from the loss of support.
Old 12-18-2017, 06:19 AM
jsoluna's Avatar
This drawbar was one of the first things I took off the tractor when I first got it and I never really payed close attention to it until now.
Looks like a drawbar off a Sears that someone cut an access hole in for the rear end fill plug.
Old 12-18-2017, 08:10 AM
Great post Jsoluna! I don't know how I missed it but time for me to sit back and enjoy. I have a 1650 that needs the same repairs made.
Old 12-18-2017, 08:28 AM
jbrewer's Avatar
jbrewer jbrewer is offline
You're making really good progress on a nice tractor! Thanks for taking the time to share the info.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
