FWIW The mag 20 that I put in my 782 has an 1 1/8" crank, the same as the KT-17 that I replaced. The mag shaft is longer and had to use a spacer on the outside of the PTO. (this mag was out of a Huskee GT)
Here's what I would do.
Step 1. Start the engine and let it run at about 1000rpm. Step 2. Take a grinder to the crankshaft until it's pretty close to the right size. Step 3. Leave the engine running and finish sizing the crank with a file. Step 4. Install new crank seal. Step 5. Install PTO.
The serial number of the 1872 you sold me Tim is 775,494 , the Magnum 18 in it can't be the original 930hr engine. The poor welded assembly drive plate, one thinner and larger spacer under the engine hold by one longer bolt, the drive shaft roll pin replace by a bold are all sign of a previous swap but maybe I don't know what I'm talking about and they are just bad fix. From serial number :756,300 to 799,999 all 2072 Cub Cadet Magnum 20 engine have 1-1/4 crankshaft, Kohler number 52 014 71-S That's exactly what Joe send me, a low hour original Cub Cadet in very good condition and a soon I receive the new assemble drive plate I finish this "simple" swap PS: Someone offer me a PTO
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
Check your PM Gilles.................
Joe 1200 Puller[/U][/B] 1864 2072 with 54 Inch Haban Blade |
Jb weld.
Now I know who did the bad fix on that 1872...
Done Joe thank you! Don't lesson to him he most have been in contact with hazardous chemical in the paint shop...
I'm glad you were entertained, I think some people might have taken me a bit to serious.
