That looks more like it! Quote:
It's black and white to me. Good advice is good, bad advice is bad. I will compliment good advice.... and that was good.
Thank you. Confirms the issue with it being too long. Quote:
Thanks for the details on removing it without taking the engine out. I don't think the service manual mentions to remove the input yoke, just the bolts on the rag joint. And that sure didn't work. This 1200 driveline is going to be the death of me. Fortunately the 149 is going strong...
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus |
How's the house going? |
The house is coming along great. Thanks for asking. I can't believe how quickly it's coming along. Of course now that framing is done, the finish work will seem like it's taking forever.
I don't know Jason, never had to.
House is looking great! |
Jeff |
I never had a doubt.
I got the old driveshaft apart and laid it next to my old, broken shaft that I believe is correct. I wanted to compare everything, and the middle hole, that holds the spring is different than one shaft I have.
There are 3 shafts pictured, the one on top was in my tractor when I bought it, it had a NF clutch fork on it, but otherwise seemed to work. The 2nd, broken, shaft I bought as an assembly from a 1200 on e-Bay (clutch plates, fork, spring etch). It appears to be all original, so I have no reason to think it isn't right. The bottom shaft is the one I got from Jeff. Quick background, the middle shaft broke, so I swapped out the top shaft that I had from my tractor originally (but with the wrong fork). It was in my tractor most recently. As you can see, the first 2 holes line up on all 3, those are for the clutch plates. The 2nd hole, that holds the spring, lines up across all 3 at approx 9 1/4". However on the 2nd shaft, the one I bought as an assembly from a 1200 online, has a 3rd hole approx 1.5" further back. This is where the spring was on it. It sits at about 10 5/8" from the driver. Interestingly enough, neither of those measurements match the pic of a shaft Lew attached. Which is at approx 9 7/8" (3rd pic) Finally, the last holes line up on the 2 shafts that worked in my 1200. What is everyone's thoughts on the middle hole where the spring rests? Is the hole that is across all 3 shafts at the rights spot? The clutch worked fine when it was placed there on the top shaft. The only issue I had was vibrations. Which I've now narrowed down to a wobbly input yoke, and an off center hole on the driveshaft. Also, the hole for the creeper is different between the 3 shafts. Not an issue for my use, but noteworthy Do I have everyone's head spinning yet? Because mine sure is....
