Low hr M20 issue
After "swapping" this low hr M20 in my 1872 (Now 2072), I found out really quick, it's not going be a turn key swap. The carburetor got issues, some sludge where hiding behind those shield but no oil leak from both crank oil seal and head gasket. I clean the engine put it back together and in the 1972 he goes.
I decided to do some tuning and testing, I manage to make it run smoother but the carb still need to be restore. no big deal since the M18 got one running well I swap that later if need. Things get wear when I did a compression test here the result after 10 minutes warm up. First test cylinder one 105psi First test cylinder two 75psi I warm up the engine again and give it another try: Second test cylinder one 95psi (sorry this one is out of focus) Second test cylinder two 89psi I think it's a bit low for a 200hr engine, I suspect a valves leak so as soon I found out how to find the dead center position on this engine I will do a leak test. If my suspicion are right I need to remove that engine from the cub and open it, This need to wait a bit... story to followed soon...
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
Head gaskets are another good thing to check, if the engine has a blown gasket it can cause bad readings on a compression test. Just something else to check out.
-Ryan
Good thinking Ryan! Having variable result like that make me think "Sticky valves", since that engine was sitting in a corner for few years it make sense but I'm not ready to remove the engine from that cub, my expensive Canadian made cherry picker hydraulic cylinder crap out! Kapout! I will pick a cheap Harbor freight air/hydraulic Friday ($72 with a 20% coupon), no way I spend $500 on a new OEM cylinder or lost my time rebuilding the old one .....To be continue
-Ryan
ol Skull,
Been my findings that the M-18's run in the #90 range. I have 4 engines that reflect that. One engine has new .010 overbore, pistons & rings and about 50 hrs running time and both cyl read #92 The M-20 is stroked a bit, so it could run higher, they say + or - 10% and with carb butterfly wide open You can check valve clearance, but I say run it a bit and get a "feel" for it. |
http://www.onlycubcadets.net/forum/s...ghlight=Magnum Now you tell me you got four M-18 in the 90psi and among them one partially rebuild with 50hr on the counter! G...I think I have a brain fart.....Cricket.....cricket
Edit: Found it; if the difference between cylinders is greater than 15% or the pressure is less than 90psi, service is basically required.
-Ryan
I'd run it a while and see if it comes out of it. Make sure it's tuned up right, fuel system clean.... then run it. Work it hard. It may just surprise you.
Ryan is right about the manual saying 15% or under 90 psi engine need services, that why George statement surprise me a bit but he is not a young spring chicken and have done a few before and even if his tools are old as he is, they are like him build from a era of quality and perfection...( I'm such a..hole licker, you can pay me later George)
Joke aside I really don't know what to think, for me 90psi is way lower then anything I work on before, these are very low compression engine so I walk in darkness territory here and I try to avoid stumbling on the carpet flowers... For now my cranium Hamster need to be feed before he spin the wheel on high gear so i'll be back in a jiffy!
Thread Tools | |
Display Modes | |
