129 deck and PTO belt size?
This 129 that I recently "drug home" is going to need a new spindle belt and the PTO belt. The deck tag says 483-U1111, it has the cast nose piece and measures 47 1/2 blade tip to blade tip. So, I guess it's a 48 inch deck but I can't find any info on it. Would the belts be the same as other 48 inch decks that are listed?
If anybody knows the length and width, I will check TSC and see if they have them. |
The information you are looking for is located in the Technical Library for Implements, specifically CPE-2B.
Spindle Belt: IH-489399-R1 (1/2" x 80) PTO Belt: IH-490489-R2 (3/8" x 80)
Thank you very much Roland, I really appreciate it. I just went to CPE-2B that you referenced, maybe next time I can find it without having to ask. Ray
update on the 129
I bought a couple belts today, however TSC didn't have a 3/8 X 80 so I bought two 1/2 X 80. The one for the spindles is a perfect fit. The one for the PTO didn't work. You would think it would be too tight but actually it was a couple inches too long. I took it back and got a 1/2 X 78 and it fit perfectly.
I tried the deck out, it and the PTO worked good, needs new blades though. I had replaced the idler pulley and greased the spindles earlier. There seems to be no hydro or oil leaks so I put it back together and will use it as is for awhile. I rebuilt the carb., new points and plug, air filter, changed oil, etc. One thing I did notice, when I touched the S/G quite awhile after I shut it down, it was still pretty hot. Is this a common thing or should I pull it off and check it out? -Ray |
