1250 hydro leak
Where is the most common hydro leak area? Its not the hydro relief valves. I'm hearing about a cork gasket problem. Where is this located? Any help would be appreciated.
Thanks |
The cork gasket is the gasket between the hydro unit and the rear end. Clean everything well and sprinkle some talcum powder around where you think it is leaking. The leak will show up.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Thanks Mortten. You wouldn't happen to have a diagram to show location and a part number of that gasket? |
Just go to partstree.com or cub cadet parts look up and it will be there on the exploded view
921-3004. Available from Cub or sponsors above.
I keep hearing horror stories of the cork gasket still leaking after installing new one. Should I use Form a Gasket along with the new cork gasket?
Can't say I have heard the "horror story" of a new cork gasket leaking. I have used a small film of gasket sealant on my gasket replacements with good success.
You use the black Permatex stuff? |
I forget the brand name, but it was black.
