Greg Rozar AKA- CubDieselFan
Old 09-19-2017, 09:53 PM
Dirty Steve's Avatar
Sounds good!
Old 09-19-2017, 11:31 PM
Very nice, sounds good. They've got such a great "voice"...
Old 09-19-2017, 11:51 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Originally Posted by smalljob View Post
I was able to locate another part to replaced my worn one ( Thanks Lew )and I have a new drive shaft on order( Thanks Jeff). The original one is badly worn where the throwout bearing sits. I had the same issue with the 100 I restored. Also needed a new throwout bearing, and needle bearing.
Today I finally finished up the engine ( less putting on the oil bath filter only because I don't want to be knocking into it). I resolved the sticking governor disk and made up a copper fuel line and managed to bend it successfully on the second try.
https://youtu.be/b6bHj16B-Y8
Next step is to get the clutch parts painted and assembled once I get everything. Then hopefully I can do a test drive.
Very Nice work!! Thanks for the video.. amazing how sweet and smooth those little 7hp K series run...
Jay
Proud owner of the following:
Old 09-23-2017, 11:24 AM
smalljob's Avatar
smalljob smalljob is offline
Played around with some 1/8 x 3/4 stock this morning. From pictures I think the original stock might have been 5/8 but. Could only find 1/2 and 3/4 so I went with the 3/4. Still need to paint it up. Because I don't have a brake to handle 1/8 I did this with a vise and 4lb hammer so bend is not as crisp.
Old 09-23-2017, 01:24 PM
john hall's Avatar
Unless you are going for PERFECT in this restoration, I think it looks very nice.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-23-2017, 01:57 PM
smalljob's Avatar
Thanks John, Just trying to make it look as close as it should as I can . I don't have the correct fuel line and pretty sure it is not the "correct" starter/generator. The S/G has a plug in the rear housing where the oil fitting would be, but the front housing does not have that.
Old 09-23-2017, 05:49 PM
smalljob's Avatar
I received that new drive shaft made up by Jeff. Looks to nice to put under the tractor. Should use it as a hood ornament.
Old 09-23-2017, 08:07 PM
I'll sell you a second one for the hood
Thanks
Bracket looks good.
Old 09-24-2017, 12:29 PM
smalljob's Avatar
Mounted the new bracket and the oil bath filter.
Question: How much of the steel wool type material is suppose to be in there? See picture. I pulled it all out and cleaned it thoroughly but it just seems like a lot.
Old 09-24-2017, 07:29 PM
jaynjeep's Avatar
Your bracket looks good
I've never had one of those oil bath air cleaners apart but others that I have had apart were pretty full of the steel wool type material.. based on others I think that is about the right amount.
Your progress looks good. Thanks for the pics and update!!
Jay
