Greg Rozar AKA- CubDieselFan
Old 08-26-2017, 08:33 AM
Dirty Steve's Avatar
Coerced my brother to weld the A-frame after I straightening the one side. Was able to rattle some color on it last evening. Hoping to get the back of the blade area cleaned up and painted today. Then onto drilling holes for the new cutting edge. Still not sure how I am going to keep the cutting edge from rolling under from hard use.
Old 08-26-2017, 08:44 AM
DieselDoctor's Avatar
Lookin' good Steve! I hate to say it, but given the chill in the air this morning, it won't be long before you're going to need it. After all, we do live in NY!
Old 08-26-2017, 09:21 AM
Doc, I had 44 degrees this morning@ 0530! Dew so thick I thought it rained. As late as crops are, sure hope we don't get an early frost.
Old 08-26-2017, 10:06 AM
Only 53 here in SW VA global warming my A$$, wearing a sweat shirt in August is BS
Old 08-26-2017, 12:38 PM
mortten mortten is offline
Wifey wasn't happy with me leaving the bedroom windows open last night. Good sleeping though
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 08-26-2017, 01:37 PM
Rattlecan Steve at it again. I cleaned off any loose paint and scale with wire cup on the 4.5 inch grinder. Then bombs away.
Old 08-26-2017, 06:16 PM
Looks black
Old 08-26-2017, 09:34 PM
Looks black, but soon to be in the white stuff....
Up to 530 and counting...
Old 08-27-2017, 06:40 PM
Found some knurled style carriage bolts. I can't drill a square hole. I set about measuring to get the new cutting edge semi square. It is a 1/4 inch thick x 4 inch wide piece of steel. A little beefy'r than original cutting edge. Once I was satisified I drilled the holes, took it back off and rattle bombed it. Huh, guess I did not take a picture of the cutting edge wearing black..... Getting closer.
Old 08-27-2017, 06:49 PM
Also decided to rebuild the two hydraulic valves on the 2182. While mowing with it the deck settled quickly. Got those rebuilt last night and put it all back together this morning. Had to remove radiator to get to them. Sucks to have to put it all back together to try them. I hope I did each valve correctly. Would be a big let down to have to tear it all apart again.
Also swapped out that mangled up hammer strap hitch previous owner mess with a different cover and hitch.
