#21
So how much HP did your engine make? Well there's all those rules on covering the engine and the clutch. Using billet steel and the clutch. Plus I need a valve to shut down boost if something were to happen. The hardest part is that since there's not much out the for performance parts I have to have most everything made.
#22
sorry no numbers
The dyno we barrowed didn't register below 200hp so I can't tell you horse numbers. We just needed to be able to load the motor back to back times to make adjustments and monitor temps. Boost shutdown is easy use an exhaust flapper opperated by a morse or choke cable to cover air inlet to turbo. A local machine shop can turn out a steel flywheel for you.
#23
Well that's to bad u couldn't find out what it had at the time. Yeah I was just thinking about that, wondering where id get a flywheel. Another thing, did you use an automotive drivetrain to get all the power to the ground? A lot of people I've notice are using a dart rearend. I was just going to use a cub transmission but I know ill tear it up pretty quick.
#24
Your not seeing the trick. You use a dodge carrier with a cadet ring gear bolted to it, inside a cadet transmission. The common thing to do is eliminate rev. and add another forward gear. Also you can get a front reduction gear set to further change your ratios. Check out midwest supercub that will give an idea of whats available for gears. My diesel had a 10% overspeed in the front reduction and a 27 tooth high gear (one tooth of overdrive, 26 is 1:1)
I ran a 26 x 12 x 12 bar tire. P.S. If you think you can control it and the rules dont say "no limited slip rearends", you can fit a dodge cone type limited slip into the rearend however its tight. |
#25
Ah yes I got it now. And it is a tight fit. A little grinding is necessary, but after that, all is good. I've looked into the get sets they have so I know what my options are. So basically once the carrier is installed just have the Dodge axle shafts shortened and all is good!
