#31
The filter is a NAPA Gold 1084. What is the correct one?
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
#32
Napa 1410. The 1084 is similar.... but it isn't a hydraulic filter. They are the same physical size, so it's the shafts fault it was hitting.
#33
Ok, I will get a 1410, and I will look tomorrow and see what parts I need.
#34
That pin on front of of driveshaft should be hardened solid, not spirol rolled.
Steven __________________________________________ 127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720. |
#35
Ok, thanks.
#36
You keep saying that, but we've already told you what you need..... Pretty much a whole new driveline.
#37
X-2
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#38
You got a picture of the front drive hub? Id like to see the wear on that, but yes what all have said new driveline. That machine has seen alot of years; good of you to catch it in time before major damage.
#39
Getting expensive, isn't it??
With a great Cub like a 149, Id bite the bullet and spend whatever is needed to make things truly right. You will be rewarded with a great tractor that will give may years of service. I am in the process of doing the same with a 149 equipped with a Danco front end loader. |
#40
Hydro Filter 149
J-Mech, You stated the correct hydro filter for the 149 was a NAPA 1410. I bought the 1084 for my 149. After looking at the ccc cross reference sheet, I see a hydro filter for a auto gear pump and a 1410 filter. Will the 1084 filter work ok for my 149 or should I exchange it for the 1410? Thanks and have a great day.
Bob |
