Cyclops plastic painting/finishing
I know someone out there has figured out a good method or type of paint to get the plastic back to a deceit looking finish. starting on Rescue11's 1864, and trying to figure out what to do about his plastic. it's all in good condition but just plain ugly..... is there a buffing process or painting or WHAT????
if you want to try buffing it i suggest wet sanding it with 2000 grit and then using a buffer on it, it may or may not work depending on the condition of the plastic. if you want to paint it i suggest scuffing it with a red scuff pad and then wash it with hot water and dawn dish soap, this will help remove the mold release agent thats in the plastic and is the reason its so hard to get paint to stick. once its washed use an adhesion promoter( heres what i use with excellent results http://www.amazon.com/Kleanstrip-ETP...esion+promoter) and follow it up with your paint of choice.
I used rubbing compound,the red stuff,on a few I had and it came out great,deep scratches will not go away.
What this video; https://youtu.be/sdQy_dfZM84 |
Buffing with a heavy cutting compound and following up with lighter polishing compound yields excellent results. The more steps you use the better it will look..
There is a very good post on here from member ccguy about restoring the plastic.. His 1440 looks like new. The plastic on my 1782 was solid but ugly.. It was dull and discolored. 20 min with several different compounds, a foam pad and a buffer have the hood looking like new! good luck with it
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
I just did a set of side panels and a hood.
Step 1. Brillo or S.O.S pad Step 2. Maguires # 49 Marine/RV oxidation remover Step 3. Maguires # 45 Marine/RV polish Step 4. Maguires # 56 Marine/RV wax All three maguires products come together in a kit. I use a high speed rotary buffer for # 49, and 45. Wax is done by hand. They come out looking new.
Charles________________________ 1572 3pnt, rear PTO, 50" deck 1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow 1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow 2072 3pnt 50" deck, Brinly Plow 2072 50" deck Cub Cadet Tank 50 Zero Turn Cub Cadet 33" Commercial Walk Behind 1953 Ih Cub with just about every implement New Holland TC33D with Loader and Backhoe |
There are several ways to restore the plastic..
CCGUY did a really good job on a 1440 several years ago.. He outlines his procedure in post 23 of this thread http://www.onlycubcadets.net/forum/s...plastic&page=3
