60" Deck on an 1772
I have a 190-325-100 60" deck that I want to put on my 1772. Is the PTO pulley the same size on the 1772 vs 1782 where the deck came off of. Also is the mower center pulley the same size on a 190-374-100 60" deck off a 982????
The 1782 had two different PTO clutches. The earlier one was the same as the 1772, and the later one was different.
Thanks, I am trying to find the dia. differences between the tractor pto's and the newer vs older center pullies on the decks.
The later version of the Haban 60 was 190-325-100 Center pulleys are different.
If you want to use a 190-325-100 on a 1772 all you need to do is to replace the center pulley with part # HA-14241 Pulley, Center. They are interchangeable. If you have a 190-374-100 just swap the center pulley to the 325
Thread Tools | |
Display Modes | |
