Greg Rozar AKA- CubDieselFan
Old 11-09-2015, 05:39 AM
Tankman's Avatar
Tankman Tankman is offline
Default Snow Blade 1641
Well I did get a snow blade for my 1641. Works great.
Can't stand gettin' up just to angle the blade; left or right.
No front hydraulics. Anyone ever fab a manual setup to angle the blade from the driver's seat?
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 11-09-2015, 06:10 AM
The 1641 uses a Hydro Gear (HG) Hydro-static Transmission. If it is anything like the Sundstrand, it would have to be a "ported" transmission to utilize an extra hydraulic circuit. I am not familiar with HG and don't know if there is a "ported" transmission alternative.
Roland Bedell
Buy: Made in the USA
Old 11-09-2015, 06:47 AM
Tankman's Avatar
Thanks Roland, I've had, for the most part, gear drive garden tractors.
I'm thinking, "Perhaps an electric linear actuator?"
Anyone have plans for this project? Or a manual blade angle setup?
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 11-09-2015, 07:20 AM
You could add an extra valve and front hydraulics then put a ram on the blade. Try the sponsors to see if you can find the parts to do it.
Old 11-09-2015, 01:55 PM
Berwil's Avatar
Berwil Berwil is offline
Member CADplans put a manual angle gravely or wheel horse blade on his 1000, although I can't find the thread. Since it mounts similar to your 1641, maybe you can pm him and ask how difficult it was to make fit.
Bill
Old 11-21-2015, 09:45 AM
Tankman's Avatar
Getting ready for nasty white junque.
Decided to use an electric actuator salvaged from a Simplicity 3-point hitch.
The actuator tested, can raise the tractor rear tires off the floor. More than enough power to angle a blade and hold same in place.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 11-21-2015, 10:27 AM
The Craftsman blade I just got rid of had a long handle with a trigger that used a cable to release the lock on the angle, then I guess you would go forward or back to get the angle you wanted and release the trigger, pretty simple
