42 inch snow plow help
Hey guys I'm hoping you can help me out. Over the weekend I just picked up a narrow frame 42 inch plow for my 147. The plow needs some work, I've got to put a new cutting edge on and re-skin the blade. I also have to straighten out the A frame as the PO had hit a tree stump and buckled it. My question is at the back of the A frame where it hooks to the sub frame there is a rod that goes across. Should this be welded in place? It seems to me it should not as at first glance I can't see how you would hook it up if you can't move the bar. Maybe I'm missing something obvious here?
Thanks guys, Curt |
It's welded in place. If you examine it closely, you will see the busted welds.
The undercarriage is tension held in place. You have to pry the ears apart to slip/snap back over the rod. |
Ahhh ok. That's what it looked like but I thought there must be a better way than caveman style. Thank you for your help! Now I've got to get the sub frame converted from bolt on to QA.
Curt |
