Greg Rozar AKA- CubDieselFan
Old 12-29-2014, 09:03 PM
bocephus1991's Avatar
Very nice! I keep trying to convince the wife to let me get 220 wired up in my basement garage. Dad has a 80's vintage century arc welder and a 80 gallon upright compressor he'd let me have.
Brian
Old 12-30-2014, 08:05 AM
Steve149's Avatar
Steve149 Steve149 is offline
Very nice welder Steve. I don't know how experienced you are but I suggest ( if it's new to you ) either taking a Vo Tech class to learn to weld or have an experienced MIG welder show you the correct way to set it up and what to listen for.
Thanks Jeff this is definitely new to me. I have welded with acetylene and stick so this should prove interesting.
Old 12-30-2014, 09:21 AM
You're gonna love that welder, Steve. I've got a Handler 140 I've had about 6 yrs or so, use it every week. If you can stick weld, you'll be all over this.
Old 12-30-2014, 09:56 AM
Steve149's Avatar
Good to hear...Just need to get a handle on the heat settings and how much gas to run other than that I don't see any issues.
Old 01-08-2015, 12:01 PM
MikeC MikeC is offline
Steve,
The chart on the spool door cover will get you near enough to make minute adjustments and you'll be welding in no time. It takes into account thickness of metal, wire speed, heat setting and type of gas mix. It's pretty accurate.
MikeC
"It isn't bragging if you've done it."
Old 01-13-2015, 11:02 AM
CubCadet129 CubCadet129 is offline
Smile
Nice tools!! I will prolly be waayyyy off on this but is that last smooth weld pic you posted some sort of custom sleeve hitch to pin or ball hitch adapter??
Old 04-11-2015, 07:47 PM
More CL shopping today
I should have it hooked up shortly, the tig will allow me to do a lot more different parts ( both cub and motorcycle related )
Old 04-13-2015, 12:31 PM
Nice rig Sparky!
Old 04-13-2015, 09:37 PM
Nice rig Sparky!
Thanks Sam
Old 07-18-2015, 06:43 PM
Bought a "Q" size argon bottle ( about 3' tall ) for the TIG welder.
The empty bottle was $268 and I purchased it thru work at their discount.
