Greg Rozar AKA- CubDieselFan
Old 11-17-2017, 11:27 AM
MattC's Avatar
MattC MattC is offline
Default Cub 127 Hydrostatic Issue
Hello all,
I recently added a Cub 127 to my growing fleet. The tractor ran fine the first couple of times I used it. The only issue I had is that it wanted to creep when in neutral.
I didn't want the tractor to start creeping when I turned it on, so I flipped the tow valve up first. After starting the tractor I put the valve back down. My problem is that the valve did not engage the hydrostatic. I am now stuck, unable to move the selector out of neutral.
Is this a common problem? Am I overlooking something simple? I did a quick search and didn't find much on the issue.
Current Fleet: 100, 126, 147, 128, 1450, 1650
Old 11-17-2017, 11:36 AM
Is the brake on? The lever won't move with the brake on.
Old 11-17-2017, 11:48 AM
IF.....everything is original to the Tractor, then it should have the Check (or Relief) valve as seen on the right.
The possibility exists that if the "plunger" is stuck in the down position, you would experience what you are having.
You can use some penetrate (ie: PB Blaster, Kroil, etc) and spray the plunger area. Make sure the plunger moves "freely".
Roland Bedell
Buy: Made in the USA
Old 11-17-2017, 11:50 AM
Just curious how the check valve's would effect the lever in the dash moving?
Old 11-17-2017, 11:55 AM
I was assuming he was referring to the handle on the Tunnel Cover.
Roland Bedell
Old 11-17-2017, 12:01 PM
I believe he was but the valve's wouldn't stop the dash lever from moving, at least I don't think they would. It almost has to be the brake on or something came apart in the linkage.
