Greg Rozar AKA- CubDieselFan
Old 07-07-2017, 04:41 PM
Shotgun Clay Shotgun Clay is offline
Default QA42A replacement pulley
Hi, where can I get a new pulley for my snowthrower? The one on it was cheap and had broken and welded by the PO. I want to get a new one that is not bent.
Thanks for your help!
Clay
149, 125, 100 w/ rear pto, fenders, and hydraulic lift. 5 snow plows, 1snow thrower, #2 ih cart
Old 07-07-2017, 06:00 PM
Seen this... http://www.ebay.com/itm/Cub-Cadet-IH...gAAOSwmCVY9n2f
Roland Bedell
Buy: Made in the USA
Old 07-07-2017, 08:39 PM
Is there any cheaper but still good aftermarket brands? I just need something that can work without worry.
Clay
Old 07-07-2017, 08:47 PM
Try www.surpluscenter.com they have quality Browning cast iron pulleys most times.
Old 07-08-2017, 12:55 AM
You didn't say in your original post that you wanted cheap parts. If price is what you are chasing, then Tractor Supply Company can probably fix you right up.
Roland Bedell
Old 07-08-2017, 07:10 AM
john hall's Avatar
If you know your sizes:
V-Belt Supply http://www.vbeltsupply.com/
Also try McMaster Carr--best search feature on the internet!!
Sometimes pulleys and sprockets can be bought with "blank" bores--you have to machine the bore, broach the key and sometimes install the setscrew.
Tractor Supply and Shoup carry a line of build your own sprockets and pulleys. Basically you buy a hub to fit the shaft and key. Then you buy the corresponding pulley or sprocket. Take them home and weld the 2 together.
I think I have done one of the "weld your own" styles before. Certainly used the ones you have to finish machine. Not something you want to do unless you have no choice, as it can get time consuming and or expensive considering broaches and pulley taps.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-08-2017, 08:21 AM
You don't want a stamped steel pulley or a zinc one, they will go to Hell in a hurry.
I've seen those throwers eat every bit of 18 Hp when blowing snow back up in the the atmosphere.
And when you loose a pulley, you get out the hand shovel or pay someone in a blizzard big $$$ to finish the job.
Some places you can save $$, other places you have to CYA.
An inadequate pulley is like a cheap condom.
Thread Tools
Display Modes
