Greg Rozar AKA- CubDieselFan
Old 03-08-2017, 10:54 AM
jim nicholson jim nicholson is offline
Default Foot control for hydrostat
I have a 1440 Cub/Mtd and I hate the dash speed control for the trans. Has anybody converted one to foot control ?
James
Old 03-08-2017, 12:13 PM
john hall's Avatar
99% positive I have seen pics of it done. I want to say it was detailed on OCC. I'm sure someone will be along shortly with details.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-10-2017, 09:56 AM
Bamafan's Avatar
Bamafan Bamafan is offline
Check out this you tube.
https://www.youtube.com/watch?v=WtLPzACxn-8
Larry
Old 03-10-2017, 03:09 PM
x.bhamcb x.bhamcb is offline
Originally Posted by Bamafan View Post
That is pretty slick. I would probably shorten the lower bar a little title more though.
Old 03-10-2017, 04:40 PM
NOW,,, someone needs to convert it to a TWO pedal foot control.
Once you use a hydro with separate pedals for forward and reverse,, you can not consider a one pedal.
Keep your heel on the floorboard, and simply swing your ankle between the pedals.
With a 1 pedal dual control,,, you are constantly holding your foot in the air.
From looking at this one, I think you would only need one more rotating shaft,, and a connecting link.
Old 03-11-2017, 07:45 PM
spudder spudder is offline
The two pedal control is the way to go. I think you could use the pedals from a 3000 series Cub. The linkages could be modified to work on earlier Cubs.
I bought a 1864, it's just grown from there. The Cubs have replaced old Chevys as my hobby/passion. The only car I have left is a '67 Chevelle wagon.
Seems like a good trade off. I can put five Cubs where one car sat and there are no titles or license to fool with!
Old 04-22-2017, 11:59 AM
Ikea6e Ikea6e is offline
Check here.
http://www.onlycubcadets.net/forum/s...ad.php?t=37406
http://www.onlycubcadets.net/forum/s...ad.php?t=37377
Old 06-14-2017, 02:12 AM
Cookieone's Avatar
Cookieone Cookieone is offline
I have attempted to do this to 1812. My approach has been to disconnect the factory tie rod ends and leave everything else intact. I've had it all working but my rtn wasn't working right. And it worked great until throttle up. Then it would stick on fed high till I hit the brake. I did 2 seperste pedals and used springs at the pedals for rtn. I got burned out and put it back to factory. But I think when I work on it again I'll try rtn springs at the linkage on the pump.
1812 custom cat0 3point hitch, foot pedal, 2155 JI Case 470 shuttle speed.
Old 06-16-2017, 11:03 AM
Which one did you try? The 1862 or the 1811?
Old 07-04-2017, 12:06 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Default foot controll hydro
Check out this foot control
https://www.youtube.com/watch?v=L7nnhPkSg8g
