Greg Rozar AKA- CubDieselFan
Old 06-11-2018, 09:24 PM
My favorite mowing deck by far is a 48" triangle deck. I've used others and consistently the best looking final end result is from the triangle deck. Your results may vary.
Old 06-11-2018, 09:28 PM
chzuck chzuck is offline
I didn’t find my receipt to figure out what blades I bought. After a little searching on the Stens site, I found blades that will work with some slight modifications. The OEM Cub blades are spec’d at 17.66” center and 16.03” outer.
Part #325-179 is 18” w/ a 3/4” hole. The length would need trimmed.
Part #330-356 is 16” w/ an 11/16” hole. The hole would need opened up to 3/4”.
Thanks, greatly appreciate your looking. And just to make sure, these do have more lift than the original?
Old 07-26-2018, 10:42 PM
Got the blades and the modifications are made. Will be trying them out tomorrow.
Old 07-27-2018, 12:32 PM
IHinIN IHinIN is offline
The blade part numbers I gave were for high lift blades. Are those the blades you bought?
Old 07-27-2018, 12:34 PM
Yes, I bought the exact ones you gave me numbers for.
When I installed them the very end of the wings hit at various places on the left and center blade, so I could not try them. I will pull the deck later and fit them.
Old 07-28-2018, 09:31 AM
I ended up grinding a taper on the wing portion of the blades and that gave me the clearance I needed between the wing edge and baffle. All mounted and ready for the next mowing.
Old 07-28-2018, 02:18 PM
cooperino's Avatar
Hope that works ok for you. Blades are meant to be balanced. You would want to be at least close to removing same amount from both sides. A couple of blades out of balance could make for a shaky machine. Not to mention prolonged use could be bad for spindle bearings. Some years ago I had a blade balance tool hanging around the garage. I think most hardware stores still sell them.
Old 07-28-2018, 04:56 PM
I've never, ever balanced a mower blade after sharpening. The other day, I sharpened my blades. When I got done, I thought, "What the hevk, let's see how balanced they are.". So, I hung them on a screwdriver and set the blade horizontally. Never moved. Gave it a bit of a spin.... always just randomly stopped. Guess it isn't that hard to keep them "balanced".
Old 07-28-2018, 06:16 PM
ironman's Avatar
ironman ironman is offline
I just sharpened these today. Let me know if you figure out how to balance them.
Old 07-28-2018, 06:33 PM
You bet, always check balance. I use one of those cone balancers.
Thread Tools
Display Modes
