#21
A couple pics of the pump adapter. If you look at yours a chunk of it is missing where a bolt goes through it.
#22
Make the steel hoods work. If the only issue is that it hits the air filter housing..... fix it. It should not need spacers under the front grille. Remember, they tucked the diesel into those exact same hoods before they ever built the cyclops series. It WILL FIT! |
#23
I looked all over both ends of my driveshaft and do not see any grease zirks...what's the odds that I don't have any?
Paul F Infantry Veteran Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G |
#24
782D engine was mounted different yes... radiator was in front and air cleaner was mounted different. What I'm saying is, you should be able to make some minor changes and everything will fit fine. Really don't think it will take much. |
#25
I've never seen an adapter broken like yours but any way you need to replace it.
#26
Wow, that's a major difference...might hafta add even more shims to the front grill haha. That picture really helps, thanks...I can see I'm gonna need to drive this thing to your house and compare them side to side [/QUOTE]
Bring it by, I have heat in my garage and a pressure washer. Well get it cleaned up real good and take a good look at it. I may not have all the answers but an extra set of eyes and ideas can't hurt. I greased my CVs on my driveshaft so I can show you where yours should be. I have my 882 and 2182 to look at for ideas to make the hood fit. As already said the Kubota engine fits under the hood on my 882 and your 782D so with some work it should fit under the steel hood on the 2182.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart 882- 50c Mower Deck 2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade Case 646 FEL Case 446 |
#27
Spent some time this morning reinstalling the original pedestal. This is about it, in regards to "extra stuff" received when I bought the tractor, so it looks like I'll be buying some used parts. Will obviously be needing a dash cover, and whatever type of handle setup there is for the hydraulic lift. Was told by the previous owner that there was some sort of bushing on the steering shaft that he had to cut off, but I'm not sure what he meant? Can someone point me towards an exploded diagram? Anyhow here's a couple pics from today.
#28
Here is a link to the steering parts. http://www.partstree.com/parts/?lc=c...&dn=0040340015
#29
#30
This is my 1st Cyclops, and it appears I'm missing the hydraulic lift handle. The original handle seems to be NLA from the dealer, but there is a replacement available for $10. I've been scouring the net for photos and searching through threads, but am having a difficult time finding dash pictures for a Cyclops.
Could someone toss up a picture of either handle? I'm not sure if I want to find a good used example or purchase the replacement part. Also, how many options for mowing decks did this have? I've heard people talk about 50 and 60 inchers...were there any smaller ones? This tractor didn't have a deck or undercarriage, I've no idea how different this mule drive would be compared to something like the setup that goes under my 1282/782.
