relay test
Hey there PMDowns, welcome!
The relay is most likely a Bosch style, it should have 5 terminals 85-86 power the coil "trigger circuit" from the PTO switch, 30 should be the primary leg of the "switched circuit" From the safety switch, 87 n/o will be the switched leg to the PTO and 87a n/c will be looped to another switch or not used. Depending on how the tractor circuit is designed either power or ground will trigger the relay. thats where a diagram will help but its easy to test with a light. Good luck, Clay |
Tags |
pto |
