Greg Rozar AKA- CubDieselFan
Old 10-30-2011, 05:55 PM
You need to brace that stack to one or more of the head bolts so that it doesn't break the exhaust port off of the block.
Old 10-30-2011, 06:08 PM
CHWNY's Avatar
CHWNY CHWNY is offline
Hey Allen watch out!!! I think them two cubs behind the barn are talkin about you, paying too much attention to a sibling!! Could be a mutiny in your county.
Clay
Old 10-30-2011, 06:40 PM
only1stegall's Avatar
only1stegall only1stegall is offline
this is the second time you have suggested that... thanks.... i believe it will be fine.
mowing LT1045, plowing 149, tilling 149, parts 149...
plows, harrows, cultivators, box blade, tillers...
I like fast cars, big trucks, and yellow tractors!
My photo album
Old 10-30-2011, 06:43 PM
People have broken them off in the past...the block is not strong in that area. Why go through all the time and expense rebuilding the engine and then risk destroying it by not bracing the muffler? It's easy and simple to do and will not change how it looks.
Old 10-30-2011, 06:55 PM
Allen I'd watch it that yellow will start to climb up your back if you sit on it too much!
Glad to see it up and running! Was it worth the wait?
I feel Matt is giving you some good advice and that's cheaper then a replacement block. It's your tractor so it's your call.
Old 10-30-2011, 07:12 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Stack and moment arms
I've always wondered about the effect of a muffler attached to a continually shaking engine at the end of a long lever . I believe I'd fashion a brace too. Shouldn't be hard.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-30-2011, 07:41 PM
I borrowed these pics from here and I can't give the correct credit for it, but it is NOT my idea. But it is a great brace set up. Just in case you feel the need to brace up the exhaust.
Old 10-30-2011, 09:36 PM
Sugarmaker's Avatar
Allen,
You did a great job getting the governor gear replaced! I think the rebuild looks good, and freshening the engine will make it run cooler I think.
The gardens look more like spring. Your plowing looks like you have done that before. I would like to get a plow set up to try out too.
On the exhaust Well I took the advice from here and did brace my exhaust. Although I have not run the tractor with it yet to see how much it shakes or does not. I only have about 20 min on the rebuild. I do not have the experience with a stack on one of these Kohlers. This is my first time so I was being a little cautious. Plus I like to build stuff too. So it was part of the restoration. I fabed it this afternoon. I can say that I can rock the whole tractor with the exhaust pipe. I like you muffler I may have to do something with mine.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 10-30-2011, 11:56 PM
Awesome pics, Allen! I thoroughly enjoyed them.
Proud owner of my Original!
