I'm not an experienced belt sander guy but I just wonder if you won't have trouble taking off a lot of metal when you reshape your cutting edge to the correct angle? I have a belt sander but no belt on it. It also has a round wheel to stick a disc on. I may try it and see how it works out.
For those that use the 4" angle grinder, I have found I get the best results by far if I use a new wheel with a square edge on it. Wheels with a rounded edge and worn down are hard to put a good edge on the blades. |
I think a belt sander would be good for sharpening the blades as a lot of knife/scissor manufactures use them to put an edge on. Bill |
Touched them up some more and checked the balance with a nail in the vise.
Looks like they'll cut grass
I've used my belt sander a time or two but always end up going back to the angle grinder. Seems the sander get's them to smooth and almost a to sharp of edge and they don't seem to last as long. You don't want them knife sharp.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
I've used my stationary belt sander for my walk behind mower in the past and had good results. Dumb question for the Cub...what's the best way to remove the blades while the deck is mounted? Car ramp? Jack stands? And...is there a special arrangement for the blades when remounting them? (I'm thinkking just to make sure they don't make contact with ech other).
I use an angle grinder. It's expensive replacing belts on belt sander as it doesn't last long. The grinding disc are cheap.
I avoid the blues by moving the grinder quickly across length of the bevel. After the grind (and checking balance), I take a file to quickly knock off the burrs and smooth out the serrated edges left by the grinder.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Using a 100 grit flap wheel leaves a better longer lasting edge. Every time you blue a balde you take the hardness out of it. I found out that Oregon Gator blades have the longest life. I only used them on my mower.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
I use this Oregon blade grinder;
https://www.amazon.com/dp/B000B8L62W...I1XUCMS4QWIV4Z Didn't pay that much for it though Then I finish with an angle grinder with a flapper disc. And I always take the deck off the tractor so I can grease the spindles too. |
Bill |
