Greg Rozar AKA- CubDieselFan
Old 06-21-2017, 08:34 PM
Government Cheese Government Cheese is offline
Default K161 runs clockwise?
I have a k161 on my shop floor, I believe it was in a Cub Original. It is rope start, and I want to see if it will run but I'm not sure which way to wind the rope. Looking at the blower housing I think it would go clockwise, is that right?
Old 06-21-2017, 08:37 PM
Yes if looking at blower housing engine spins clockwise
Old 06-21-2017, 08:52 PM
My clocks digital...
Old 06-21-2017, 11:37 PM
There is only one way you can wind the rope..... that's not hard to figure out.
Old 06-22-2017, 05:06 AM
Normally I see rope starts with the notch cut at an angle so it can only be pulled from one way, but this has the notches straight up. There is nothing to keep me from winding the rope the other way.
Old 06-22-2017, 06:03 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I was intrigued by this thread regarding something so seemingly obvious. I found the Operator's Manual in the technical library and saw the electric start models has this odd little plate with the two notches that the OP is showing. Perhaps this is a backup method if the electric start fails. Manual start models for the "O" has the typical rope start assembly mounted to the the blower housing.
Queen Of The Quietlines!
Old 06-22-2017, 05:53 PM
sir_lancealot sir_lancealot is offline
That's not the rope start spool you pictured. That's just the pulley, as stated by Alvy. The two notches are where the recoil starter pins go to make connection to the crank. See the diagram linked.
http://www.cubcadet.com/equipment/AR...0-A/0118500003
