Release button popped off
The release button on my 129 popped out today while I was plowing snow. As a result, the plow fell off the tractor. I found the button in the snowbank, so that's good at least. How does it go back on? Do I just thread it back on? The spring is inside the handle still and the float button is still there as well.
Seems like every time I pull the old girl out I'm finding a new weak link in the chain. |
Had one apart a year or two ago, but don't remember the details. Pull up the parts book off of Cadets site, should be an exploded parts view.
Thanks, that helps.I found this diagram. I guess I just need to push the button down far enough I can thread it back on.
You might need to lift and hold rod #5 up as high as you can get it, and then with your other hand start threading the button back onto the rod. You'll have to push the button down a bit while you're threading it into place, there's a spring in there that needs to be compressed. Once you've gotten it on a few threads, you won't have to hold the rod up anymore. BTDT a couple of times!
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors! |
Thanks, everyone. I got it back on, I pushed the rod back up and stuck a screwdriver in the bottom to hold it up and it screwed right back on.
