the other thread just referenced should help you. You will need to remove the plug in the bearing plate to see the marks. I had to use a scotchbrite pad to clean the flywheel to find the marks. But it seems like if you set the points to 0.020, you'll be close enough for it to run without dealing with the static timing procedure. Are you sure your valves are operating? Take off the square breather cover and observe the valve stems going up and down as you rotate the engine. If your exhaust valve is stuck open, it won't fire, for example.
Update. I still have spark and all other goodies. Problem now is I've burnt up the S/G in the process. She was smoking from the outside terminal. Took it apart and the wire from one of the field coils is completely broken in half and the insulation burnt up. This is the second time I've ripped this thing apart to fix the terminal.
I talked to the guys at the IH dealer and they want just under 300 bucks for a reman S/G. Anyone know of the best place to pick up a decent S/G for less? I see them on ebay for about 125 but am hesitant without knowing the quality. Any input helps. Thanks. Cory |
Cory, check with the sponsors at the top of the page.
Take your S/G to a generator rebuild shop. It should cost less than $120.oo, but will be right. I have messed with S/G's for many years, and I will always take mine to a gen shop. Its the best money you will ever spend.
If you live too far from a gen repair shop, consider buying a new S/G off of fleabay. I bought a new one from a place in Logan, WV for $120.00, with free shipping. It was new and works great. Just my .02.
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
