Greg Rozar AKA- CubDieselFan
Old 03-24-2017, 12:19 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Default K301 hard to crank
Got a k301 in a 129. It's hard to crank, pulled the spark plug and it spins freely. Pulled the cam cover and checked the ACR and springs are in tact. The points have been timed. Carburetor has been cleaned, starter generator is good, all grounds checked. Rear end fluid and filter changed also. I have got it to fire after much resistance and it runs good and mows well, checked it out lastnight. Any ideas? Was thinking about moving this one but kinda stuck with it until I get this resolved. Thanks
-Rick
IH 782
IH 126
CCC 1863
Old 03-24-2017, 12:26 PM
Moving as in selling? Or mowing?
Old 03-24-2017, 12:43 PM
RLause's Avatar
RLause RLause is offline
Here is a link to a post where the person had a similar problem. Don't know if this will help.
http://www.onlycubcadets.net/forum/s...562#post407562
Richard
Old 03-24-2017, 12:59 PM
Rmowl's Avatar
Richard, thanks for the speedy response, i have the cam cover removed, can I see this tab from that? Honestly not sure what I'm looking for. I'll remove the engine and pan if I need to but don't want to if not needed
-Rick
IH 782
IH 126
CCC 1863
Old 03-24-2017, 01:28 PM
I guess this always had this issue or is it something that it just started doing?
Did you adjust the valves?
Up to 530 and counting...
Old 03-24-2017, 01:37 PM
RLause's Avatar
I don't know if you can see the tab with the cam cover removed or not, but it is the tab that opens the exhaust valve slightly during the compression stroke providing the compression release. You can remove the valve cover and see if the exhaust valve moves slightly on the compression stroke.
Richard
Old 03-24-2017, 01:39 PM
Rmowl's Avatar
I'm uncertain how long this issue has existed, don't know much about the history of it. It has for me anyhow. Adjusted valves, didn't make a difference. I'm gonna try advancing the timing a bit.
-Rick
IH 782
IH 126
CCC 1863
Old 03-24-2017, 02:01 PM
You may want to check your grounds on the mounting bracket for the S/G, and there should be a ground strap going from that bracket to the frame/grill attaching bolts.
Old 03-24-2017, 07:40 PM
Rmowl's Avatar
Thanks for the help Richard and lew! I didn't get her going, today was my last day to get stuff buttoned up for a while, so this one will sit on the back burner unless my buddy is feeling entergetic.... Thanks again, I'm sure it's something simple
-Rick
IH 782
IH 126
CCC 1863
Old 03-24-2017, 08:27 PM
Userj8670's Avatar
I have a 126 and in the winter it's always a bear to start...cranks really slow as the weather cools. I have replaced the wire harness (brand new) and the starter Gen (as they needed it). Short of it is, it's always done it so I just keep the battery maintainer on her in winter and it rectifys the situation. In the summer I never have a problem cranking - only cold weather lol.
