Greg Rozar AKA- CubDieselFan
Old 08-23-2015, 09:59 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Default Quiet line with a GT 46" deck??
Hey guys, I am wondering if anyone has had luck with putting a gt 46" high vacuum deck on say, a 1450? Any pictures and or information would be appreciated!
Old 08-23-2015, 10:11 PM
SS5150's Avatar
SS5150 SS5150 is offline
A friend of mine said he had that setup (Its his first Cub, was a Deere guy). I haven't had a chance to see if it has a 44" or indeed the 46" on it.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 08-23-2015, 11:35 PM
I anyone can make it work, it would be you Trent.
However, this is what I see....
The cyclops undercarriage for that deck will go on the QL.... but the cyclops sit a little higher because of the front axle. Plus, the front axle was swept forward on the cyclops giving the extra room needed for that deck. If you fitted a cyclops front axle onto a QL.... it might just "bolt" right up.
Old 08-24-2015, 12:27 AM
Berwil's Avatar
Berwil Berwil is offline
I've been eyeing up the 48" decks from the 2000 series for my 1450. The rear pins should be close enough to be made to work, the front roller bracket can be capped and eyelet bolts installed, and a longer belt sourced. The 1450 wheelbase is 44", 2185 wb is 47", when looking at pics there is much more than 3" clearance for/aft of the deck. I'm sure there are a few reasons why it won't work, but without one in front of me I haven't found out. I know I'm not much help with your question, but I've been thinking along the same lines.
Bill
Old 08-24-2015, 12:54 AM
Rescue11's Avatar
lol, the sun does shine on a fat mans @$$ every once in a while, will have to see!
The gt 46" Deck does mount on the 1811 series tractors, and they have the same front axle which made me think it "should work" The last time I tried it I got frustrated and gave up, that was 13 years ago or so...
Old 08-24-2015, 06:24 AM
j knight j knight is offline
Default 46"gt mower
The 46gt mower came with my 1810.
Now using the mower on my 782D
It does not raise as high on the 1810 stock axle as it does on the 782D with a 1864 front axle and v61 tires. Also had to use a shorter belt on the diesel. Lines up the pulleys on the mule drive better. II instead of Ii.
