Back to the subject at hand, I cannot find the serial number tag anywhere on this engine... maybe it's buried in the oil. This is a slightly off topic question, but it seems like everything I bring home has oil soaked filth everywhere, and I use engine degreaser with an air compressor engine cleaner, and pressure spray it off. My stone driveway area where I have access to this equipment is becoming an oil slick... what do you guys do? I'm starting to think maybe I should just take my stuff to a car wash and degrease it there, but then I have to feed a meter with 10lbs of quarters and rush the job to get it done. I might have to dig up my driveway and redistribute the stones.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
The Engine Serial Tag should be located, when standing in the front of the tractor looking back, on the Tin Shroud on the top, just to the right of the Carburetor.
I thought that's about where it should be, but i didn't see it. I do see the oil sentry label on the opposite side. Hopefully it'll turn up after I get the engine pulled out and cleaned...
After more degreaser and pressure spraying, I found it. Based on the serial number, the engine is a 1987 (I downloaded the service manual), and the tractor is a low serial number 1988 based on the serial number, so it sounds like it is the original engine. I'll go over it and clean it up and see whats wrong and then figure out if I want to use it in my 1912.
I always miss the "good stuff"...
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
You guys didn't miss much. Just a discussion about parting out or fixing pros and cons...
I did a compression test on this engine before I pull it out or do anything, I get about 65lbs on each side. Seems a little low... I don't see a lot of oil in the air filter, and it doesn't smoke, maybe a little at start up.
My kt17 was reading about that when I got it. I pulled the heads and resurfaced them and cleaned the valves up and when I was all done I had 95 lbs per cylinder, it runs like a champ.
Is that the one I saw of you (I think it was you) on YouTube wet sanding the head by hand?
