Take the pulley half too!
Queen Of The Quietlines! |
You can always flip it over, the back and front of the metal disc are the same as they are not marked.
105 QA36 PTO repair
83EDC9CF B506 46B2 AEA6 D6A6B13235A
Removed PTO because it was slipping, and starting to squeal. Found the pressure spring bent (see photo), and the clutch bearing dry and making noises. Ordered a “Master” PTO rebuild kit, and the one thing not included was the pressure spring. $30 for just the spring. I have no issues with the seller because a clear picture of the kit was provided in the ad. I rebuilt this PTO 4-5 yrs ago, and remember the spring looked very compressed after adjusting the double nut machine screws with the gauge, but after checking several forums it sounded like that was normal. This PTO is only used for running a QA36. I don’t know if I messed up the adjustments, or the heavy use and wild temp swings here, or both caused the failure. Going to proceed very carefully with the installation. |
PTO spring
Link doesn't work....
Did you order another spring yet? I don't recommend it as a permanent fix, but you can rebrand the spring and put it back in. It won't last forever, but it will work long enough for you to get a new one. Again: temp fix only. |
About to order a new spring. Going to wait until I have the darn thing before I put it back together. “Rebrand” ?
Probably a typo for "rebend"
All three legs of the spring are bent equally,too far to bend straight, and expect adequate spring function. Thanks, Steve
Charlie, does the hub have 6 "pins" cast into it or is it smooth?
Single spring or double spring? Jeff |
Jeff; It is a single spring. ? Cast in pins ?
Thanks ,Steve |
