Front PTO on a 105 for QA36 thrower
Can a pto be “readjusted” ? Rebuilt it 4 yrs ago, and found it was slipping ( can turn it by hand) when engaged. I do intend to get a kit and do a rebuild, but was wondering if readjusting was even possible in an emergency. Also is there a heavy duty version of the kit? I see 2 spring kits available, just not clear on their applications. Thanks, Steve
Checkout the technical section of this forum.
Go to "pto" section. Did it work after you rebuilt it? Sometimes they need to be adjusted a bit more or less than the gauge spec. |
Later WF tractors with larger engines used a different spring. |
Hi Charlie... before going too far I'd go thru the tech section that was listed and make sure and double check you got the adjustment right the first time. John
Did the rebuild kit 4 yrs ago and It worked well for the past 3. Primary use for the Cub is snow throwing. It just started to slip this week. Ordering a repair kit tomorrow but first I want to pull the pto, and take it apart just to have a look. Thanks for the responses, Steve
The 147 does use two discs due to the increased HP. Supposed to hold stronger.
You should be able to rotate the PTO pulley by hand (with some resistance from the fiber button on the clutch) when the clutch is disengaged--when the actuator handle is pulled back toward the operator and the fiber button is pushing in on the clutch.
When the clutch is engaged, with the actuator handle forward, the PTO pulley will turn the engine over. A properly adjusted clutch should last many years---in mowing duty, probably 15 years or more. Yes you can adjust the clutch. But you have to remove it to do so. Perhaps your locknuts (jam nuts) on the adjusting screws have come loose? You'll need a thin open end wrench plus a second one, to hold the inner nut while you tighten the outside nut. I ground down a wrench to get it thin enough.
Just found during last Sunday”s storm, that I could rotate the PTO by hand when it was engaged.(which would explain why it was throwing poorly) This rebuild will be the 2nd one I have done. Thanks, Steve
Charlie105 you may want to have the clutch surfaces resurfaced to remove any uneven areas. This may help with longevity and performance too.
Queen Of The Quietlines! |
Taking the disc to a shop to have it resurfaced before reassembly. The last rebuild I only lapped the disc ona sheet of wet/dry 100 paper. Thanks for all the input.
