Greg Rozar AKA- CubDieselFan
Old 07-07-2009, 01:18 PM
1026 1026 is offline
Default what pto belt fits my deck
I'm a new owner of a 106 (with a newish 12 hp after-maket kohler hence 1026). The mowing deck manual shows a 122 cub with 38,42 and 48" deck info. My deck looks like those types but seems to measure about 42-44" (across the blades)
Someone hand-wrote 421u1113 on the manual.
My broken belt measures 72"x3/8" so I ordered a belt from MTD that matches those specs. Does anyone know what deck I have based on the number 421u1113?
Old 07-07-2009, 03:32 PM
mrdonkey2u's Avatar
mrdonkey2u mrdonkey2u is offline
Default contact this member jkier he posted this:
found this on the site,you can also put your number in the google search engine and find other results.I looked and saw it listed as a 42" and a 48".....maybe some more knowledgeable people can shed light on that,maybe it has a suffix after the number depicting the cut size.
Originally Posted by jkier View Post
Hi all,
In the process of trying to quiet my 421u1113 deck down.
Right now it kinda sounds like I'm mowing a cat :biggrin2.gif:
I pulled the first assembly off Wednesday an soaked it for a day.
Last night I disassembled it and noticed an extra piece not shown on the diagrams I have. I'm assuming its needed but would like to make sure its a factory part.
Hopefully I get a chance this weekend to tear into another assembly and see if that part is inside as well. Just figured I ask here too.
Old 07-07-2009, 04:46 PM
Mike in NC's Avatar
Mike in NC Mike in NC is offline
Your deck is a 42". We have the same deck on one of our 128's.
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23
Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor
Old 07-07-2009, 07:10 PM
I always thought the first two numbers on the ID tag represented the cutting width, is this not correct?
Old 07-07-2009, 07:26 PM
Mike in NC's Avatar
Yes, I believe you are correct.
Old 07-15-2009, 02:24 PM
Default pto belt success
Thanks for the tips. I was able to by the belt(IH409489 r2 3/8"x80") at the local CUBMTD dealer for $25.
