Greg Rozar AKA- CubDieselFan
Old 03-26-2018, 12:56 PM
ScubaDiver1969 ScubaDiver1969 is offline
Default Engine blowing oil
I have a 2012 LGT1054 with about 400 hours on a Koehler Courage 26 engine. Went to fire it up for spring and it is blowing oil out the bottom of the engine a lot of blue smoke. I’m assuming that is from the oil hitting exist maybe? Does this sound easily fixable? I can’t quite see where the oil is coming from but the blow pattern is right above PTO assembly.
Old 03-26-2018, 01:09 PM
Those engines are known for the valve cover leaking and when it does it leaks right onto the muffler. Buy new gaskets from Cub and clean everything real good and put it back together, I used permatex ultra black silicone on the one I did for my neighbor and it's been fine since.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 03-26-2018, 01:26 PM
Would that cause the oil to blow down on the deck? Sorry if it is a dumb question ��. I can see the spray on the deck and garage floor just in front of the deck. The valve cover seals were replaced a couple years ago by a mechanic who used an epoxy or something other than a gasket.
Old 03-26-2018, 01:52 PM
Without being there to see what going on it would be hard to say. I would start by degreasing the engine to get it nice and clean which will make it much easier to see where it's coming from.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 03-26-2018, 01:55 PM
You better hope he didn't use epoxy......
Old 03-26-2018, 02:34 PM
Watch it John, you might scare him!!LOL
Old 03-26-2018, 02:35 PM
ironman's Avatar
ironman ironman is offline
Your first post gives the indication that the tractor was sitting all winter, so another possibility could be your lower crank shaft oil seal. If it weeped all winter then of course oil would get coated on everything below and sprayed everywhere when you first started up. In any event, as said above, you've got to get it cleaned up first so you can determine the source.
Old 03-26-2018, 07:52 PM
Did you check the crankcase oil level for being overfilled?
