Greg Rozar AKA- CubDieselFan
Old 10-17-2014, 09:51 AM
Default Members who sell/sponsors here
Just wanted to say thanks to Mark (Yosemite Sam), Jeff in PA, Patton Acres, and Chris Westfall - great service and quality stuff from all these guys. The drive-shaft from Jeff was almost too pretty to paint. All that drive-shaft stuff on my 129 was rigged and re-rigged poorly, so it will nearly all be new going back. Scored a nice rear hydro flange on ePay that is not all wallered out like mine, it's the only part not new. It had several too small too short roll pins inserted into one end, like the guy just kept driving more in?
Should be less scary when back together...some PO had removed the cover (I do have it though), and all that spinning stuff vibrating and flopping around was not real cool IMO. 3600 rpm is not that fast until you think about just where all that stuff points while you are seated on the tractor...
Old 10-17-2014, 01:10 PM
Steve149's Avatar
Steve149 Steve149 is offline
AMEN to that!!!
Old 10-18-2014, 08:02 AM
mickb72 mickb72 is offline
Default cub
Congrats on the hydro flange, most off the ones i see you could throw a sack of potato's threw sideways. Mike
Old 10-18-2014, 08:47 AM
Thanks. The center locating hole in mine was egg shaped, it was loose on the shaft, and pin hole wallered out. PO had really rigged all this driveline.
Old 10-18-2014, 07:45 PM
Glad I could use my skills to help you out.
Thank you very much for the kind words
Jeff
