Is the inside of the gas tank on a 129 stainless steel?
I noticed some dirt in the tank and so want to clean everything out. I was told to look for rust but I don't see any. Is it stainless? Also, the petcock had this about an inch-long crumpled up screen that was ripped near the inside of the petcock and there was alot of dirt, etc. crammed up in there.
Should I just replace the petcock with a new one? Do they typically have those screens? I dug all the dirt out and so I imagine could put it back in the way it is without any screen but I doubt that's a good idea. Are the petcocks for lawnmower gas tanks pretty standard size? Thanks... |
The tank is not stainless. I would replace the fuel shut off if it's in bad shape.
Well, the screen is shot for one thing. So buy a new petcock? Would it best to go right to a Cub / IH dealer for that or maybe pick up at a NAPA store? I've not had much luck getting tractor parts at my local auto parts store.
Called my dealer...he suggested re-using the petcock but putting an inline fuel filter between tank and carb (?) |
I forget where I got my last one but they are easily available online. You can run an inline fuel filter but make sure it's for a gravity flow system.
Here is what I used on my Gravely, but they should be the same thread size. Worked great. I would think you can get a filter relatively easily too.
http://a.co/cXPOGTV
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus |
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Thanks for the info. I cut the screen off, cleaned the valve out and will just re-use it along with a gravity-flow filter I just picked up plus a new fuel hose. I appreciate the link to the valve though.
