1250 Not Charging
My 1250 is not charging.
New voltage regulator. Regulator Plug to stator - not running: AC Top to AC bottom 0 to 0.4 ohms AC Top to gnd OL AC Bottom to gnd OL When running WOT: AC Top to AC Bottom - 37 VAC AC Top to gnd - 37 VAC AC Bottom to gnd 0.0 DC to gnd 0.0 VDC Ignition switch terminal A to Regulator plug DC 0 ohms I cleaned a rusty connection at the ignition switch Terminal B. No joy. Does anyone have any ideas? |
you need 12v to center terminal on regulator from the ignition switch if you don't have any then you might need a new ign. switch
Here is the check out procedure......... http://www.onlycubcadets.net/forum/showthread.php?t=368
I have no volts at the DC terminal of the voltage regulator (VR) running or not running, key on or key off. I checked the wire from the ignition switch to the VR and it is good. What are the terminal combinations to test the ignition switch for continuity? |
BTW....I should mention that the V/R has to have a "good" ground connection to the battery, for it to work properly.
I have the ignition switch out.
I checked continuity between terminals A and B. Key off no continuity. Key on - Terminal B is loose. If I wiggle it with the ohmmeter connected I have intermittent continuity. |
When you say good ground connection, do you mean between the body of the VR to the engine shroud? Or is there a ground wire somewhere?
I have 37 VAC at the AC terminals I have less that 1 ohm at the stator wires. |
With the tractor not running, if you pull the connector off of the v/r and turn the key just to the on position you should measure 12 volts on the center lug of the connector. That would be voltage straight from the battery. If no voltage you could have a faulty key switch, bad connection on the key switch, an open ammeter, a bad connection on the ammeter, or a bad connection in the plug that connects to the pig tail of the V/R connector. With this test you can jiggle the key and all the connections to see where your intermittancy is. Don't know if that is a word but hopefully you get the idea. You could use a meter but a test light would be easier to spot the trouble with.
The Wiring Diagram for the 1250 is in the Technical Library Section, on page 5.
