Greg Rozar AKA- CubDieselFan
Old 05-29-2011, 09:39 AM
JSampson's Avatar
JSampson JSampson is offline
this thread could be a sticky in the restore section. I am now thingking that I am going to strip down my 100 build and take it to get bead blasted instead of just cleaning up the rusted spots. Goot pics, very nicely done.
Old 08-20-2011, 08:08 AM
Merk Merk is offline
The paint I used is Napa Crossfire paint.
White paint code is 53A-3965
Yellow paint is 53A-3857
Old 10-04-2011, 10:43 PM
Uncle Dick has been a fun Cub to run. Unfortunatly the rear axle seal started to leak. The first thing I did was clean the catch pan so I could reuse the oil. I had the rear cover pulled and rear axle pulled before I thought of taking pictures.
I desided to change both seals.
Old seals were easy to pull with this tool:
Pulling seal:
Purchase one seal and rear cover gasket off Chris Westfall.
The other seal was from NAPA.
Old 10-04-2011, 10:56 PM
Tool I used to install seal:
seal installed:
I like to put a little grease on area where the seal and bearing/bushing goes.
C clips installed:
I tip the front of the tractor up so the oil that is left in the rear end drains out.
Sump looks cleaner this time compaired to the first time I opened it up 2 years ago:
Looks like Hy-Tran did it's thing.
Old 10-04-2011, 11:01 PM
I desided to reuse the Hy-Tran. I used a paint filter when I fill my container.
This is what was left after the container was filled:
The trans was refilled and so far no leaks.
Old 10-05-2011, 08:00 AM
Merk, looks good. Did you make that seal installation tool or buy it? Are you taking that tractor to the Ohio Plow Day? Make sure you take lots of pictures for us to enjoy.
Old 10-05-2011, 10:57 AM
Great job, Dale!
Proud owner of my Original!
Old 10-05-2011, 08:35 PM
Great pictures Merk
And as always you make a job like that look easy
Old 10-05-2011, 08:54 PM
by Oak
The seal install and removal tools were purchase at Sears 15-20 years ago.
I will take the 70 to Ohio Plow Day. My Wife likes to drive it around. The 70 aslo get used to pull tractors back to truck(s)-trailer(s) that quit while plowing. We usually have a gas run or 2 to make out to the field.
by ACeci
Great job, Dale!
Thanks Allen
by Diz Jr.
Great pictures Merk
Thanks. The old Cubs are easy to work on.
Old 06-26-2013, 06:13 PM
Just read this thread after seeing "Uncle Dick" at Red Power last week. I can appreciate the hard work put into it after seeing the finished product. Great job! Even better that you can keep it in the family.
