Greg Rozar AKA- CubDieselFan
Old 08-29-2017, 02:29 PM
kish-81's Avatar
kish-81 kish-81 is offline
Default mowing 101
So these are the kinds of questions that keep me up at night...
We're mowing a large (~2 acre) rectangle with no obstacles. Currently am using a LTX 1042 KW. (42" deck) We normally cut counter-clockwise to throw the clipping to the outside of the loop.
When I mow, I get to the point where at each corner, I stop and back up, then continue onto the next side of the lawn. My wife just turns the steering wheel and makes the hard 90 deg. turn. She does leave some narrow uncut swaths, but not consistently.
So is it possible, depending on your tractor, that you could always cut without backing up and never have these uncut areas on your corners? Is a wide deck and/or a tight turning radius the key factors?
It's a slow day...
Dave
now own a LTX 1042 KW
formerly had a 1620 Hydro
used a 1450 Hydro (dad's machine back in the day)
Old 08-29-2017, 03:47 PM
LMAO....I have a hydro, and don't back up. I cut rectangles and after a few rounds, then I just dead head around the ends. Much faster...but that is the way I do it.
Roland Bedell
Buy: Made in the USA
Old 08-29-2017, 04:13 PM
Is reverse broken? Why no backing up?
Old 08-29-2017, 05:24 PM
jimbob200521's Avatar
I think his wife doesn't stop and back up because it's quicker to keep going forward
Unless I'm doing a small yard, I do it like a farmer picks corn; I do several passes around the outside then go back and forth (or diagonal).
I do know what you mean about going around 90° corners, though. Just watch your outside deck cutting edge and keep it on the uncut grass and unless you're almost done, it usually comes out alright.
-Ryan
Old 08-29-2017, 06:03 PM
This is the way I do it.
Old 08-30-2017, 12:25 AM
I do the first two outside rounds, then back and forth with the 2372 Hydro. If I want to play with the 122 gear shift tractor, then I start out the same, but when the corners get to sharp, I make a loop at the corners.
Going down a side, and when I get to the end, go past the corner and turn towards the outside, make a loop then keep going...
Excuse the drawing.
Old 08-30-2017, 12:28 AM
I lay off lands, like when you plow. But it's back on forth whichever direction I mow. Never the same way back to back.
Is is possible to turn at the corners and not leave grass or make it look good..... NO. Decks are meant to have grass fed into them straight. When you turn and cut, it lays the grass over and doesn't cut well between where the blades meet. If you want a nice looking cut, square corners.... and if I were you, I'd just mow the grass myself. My wife helps occasionally..... following me with a second tractor doing exactly what I do.
