Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 03-14-2012, 12:25 PM
happyhab happyhab is offline
Default Need Help - Intek Vtwin 20hp
I have an Intek running on one cylinder. So far I have checked, swapped, replaced plugs. Then I swapped out the coil on the bad cylinder with another good one and swapped them side to side. And, they both have good sparked. I adjusted the valves. The cylinder is noticeably cooler to the touch after running for a little while so I am suspecting it is a fuel issue. I disconnected the coils and cranked the engine over for a little while with the choke on to soak the plugs. The bad side plug does not seem to be as wet as the good side. So I am thinking maybe it has something to do with the carb. However, I don't have any experience with the newer double barrel carbs. Any suggestions would be appreciated. Cheers.
Old 03-14-2012, 05:40 PM
Dumb question: Do both cylinders have compression?
Old 03-14-2012, 06:10 PM
I do not have a compression tester. However, wouldn't a dry plug suggest a fuel issue?
Old 03-14-2012, 06:40 PM
If you have broken rings, I would think the cylinder would not create a vacuum, could not suck in fuel/air mix, therefore no wet plug!!
Old 03-14-2012, 06:49 PM
Thanks...I know these Intek's are 'crap' but this one only has 550 hrs and thought maybe there might be some inherent problems that I should be looking at first. I'll have to pick up a compression tester and go from there. I think this carb shares one jet so I'm beginning to lean towards a compression issue now rather than one half of the carb being gummed up or something simple.
Old 03-16-2012, 08:25 AM
I removed the 'W' shaped inspection cover to find a small piece of grass blocking a rectangular shaped port. Problem solved.
Old 05-21-2012, 11:55 PM
clint clint is offline
Just in case you have more problems I had the same problem on a 24 HP INTEK, the intake valve had a coating of gunk, and the push rod also, so it stuck causing the exact same problem you explained.
