1864 3 point weight
I was thinking of rigging up a bracket for my three point to hang weight on, and I was checking to see how much weight that aluminum rear will take?
You'd be much better of filling the tires with fluid or getting wheel weights, hanging weight on the 3 point will be hard on the axle bearings.
I have a set of the cast iron wheel weights on there but that's not much. I personally don't like fluid in the tires, I grew up on the farm and my dad and I have always picked up tractors with fluid and the rims were rotting through. We have always done our own tire repair and when it comes to fluid or any liquid, its always a mess when something needs tire work, so I would prefer to not put anything in the tires.
WW fluid or antifreeze is it is not corrosive like calcium chloride we put in farm our tractors. |
yes when i said fluid i meant washer fluid, you dont even need a tube because it wont eat the wheel.
x3 on the fluid! We quit using calcium chloride in our farm tractors way over 30 years ago. What are you trying to do that needs so much weight anyway? Reason I say this is you said the cast iron wheel weights weren't much weight.
I know it's not the best idea to hang weight off the back, but sometimes you have to do what you have to do. Here's what's on my 1211 there's a piece of angle iron welded to the sq tube then bolted to the hitch and a bracket that's bolted to the tube and then to where the top link would mount.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
They are the cast iron ih stamped wheel weights, 25# or so.It's for snowblowing with the 450 blower and traction for the end of the driveway. Yes I do have chains on.
I don't need the weight in the summer months, its just my mowing rig so I can take the weight off. Just out of curiosity, you guys that have tillers, plows, and other attachments, how much do they weigh?
If you have problems with 200# i would simply be amazed. Thats if all of your bolts from the axle tubes to the main case are in good shape tho. I plan on putting alot more than that on mine!!
According to ASAE Standards 1997, to be considered a true cat 0 3pt, it has to be able to lift at minimum 450 lbs a minimum distance of 12". So I would guess short of you parking an M1 Abrams on your 3pt, you should be ok!
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
