Rear lift install
When installing the lower hitch link, will I lose any rear end oil when I remove the bolts? Can I reinstall the fixed draw bar over the lower hitch link? If so, how long do the new bolts have to be?
It all depends on how well the cover is sealed to the casting.
I've added lower brackets to many rear ends and it's always a crap-shoot. This is probably a good time to change the fluid and filter. On a tractor that I know has good fluid and filter, what I have learned to do, is to raise the rear end of the tractor to the point that there is no fluid contacting the rear cover when you take the bolts out. You gotta raise them pretty high (almost standing them on end) especially a hydro. After you get the lower bracket added and tightened down, let the tractor back down and watch for drips the next few days. Off hand I don't know the length of the bolts, I just use a Phillips screw driver to measure the depth of the holes and get the correct bolts out of the bin (I always use grade 8 bolts).
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
Thanks. I just went through my service manual and didn't see the filter for the rear end. Where can I get a filter and gasket and what type of oil do I use?
A quick look at my book, the draw bar and the lower link use bolts that are 1 1/4 long.
There is no filter on a gear drive.
lmao, Yes, there is no filter on a gear drive.
I probably should have also said that I use an overhead crane to lift such things. Ramps could also work, but only if you're very careful.
I did find a Cub part number for the gasket and oil. I might as well change the fluid while I'm at it. Going to rebuild the carb also. Looking for a carb kit that includes the mounting gasket.
I've never seen a carb kit that includes the mounting gasket.
IH Cub Cadet Parts on Facebook.
That must be the delux kit cause I never get the mounting gasket either
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
