will a 451 snow blower off a 2084 fit 982
I was wondering if the 451 off a 2084, will go right on my 982 with out any mods
Per the Cub Cadet Attachment Catalog.....
The listed Snowblowers for the 982 are: * 190-364 * 190-450 * H-42 (Haban) * H-48 (Haban)
Will it fit and work...Yes.
Is it the right one...No. It will work but not throw the snow as far. I ran a 451 on my 2072 for years.
Josh 1989 SGT 2072 (restored) 60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake Cub 128 with creeper and rear PTO with reverser(next project) IH built 682 and 782 that will combine to make one |
so the 450 is the one i need & it will throw the snow faaaarrrr away
is there a 54" or 60" snow blower ??
Nope. Considering the 45" ones are ~250lbs, a larger one would be so heavy you'd need 500lbs on the back just to be able to drive it around.
You need a 450 for your 982. A 451 is the same blower, it just has a different gear ratio in the gear box.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
whats the lift kit about is this some thing i can make ?
