Greg Rozar AKA- CubDieselFan
Old 06-23-2013, 08:59 PM
CadetTY's Avatar
CadetTY CadetTY is offline
Default Messing up my paint!
How do you guys not mess up the paint when putting nuts and bolts in. Like when tightning a bolt to the frame how do i stop the bolt form chewing up the paint. Do most guy just paint the reareds in the frames?
882 diesel, 782ccc, 782ih, 102, 62 original, 108 x2, 124, x3 vtwin 82 seriers pullers, 1 wide frame puller project
Old 06-23-2013, 09:45 PM
cubby102's Avatar
cubby102 cubby102 is offline
I put flat washers iin and it seems to help
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
Old 06-23-2013, 11:29 PM
If your doing a restoration... Paint everything first, install it, then paint what you scuffed when your done. There is NO WAY to prevent paint chipping..... unless you don't tighten the bolt.
Old 06-26-2013, 11:02 AM
Muzzy Muzzy is offline
I put a thin rag like an old tee shirt over the nut or bolt and then slip on a socket or wrench and tighten. It helps.
Old 06-26-2013, 09:00 PM
johncub7172's Avatar
Arrow
That helped me out! I often find myself trying too hard not to chip new paint. Dreading installing my tires to the rims. I will spray some paint like in the paint cap or something, and use a brush to repair the chip reducing a large amount of over spray. The nitrel or latex glove finger tip over a socket will work good.
